Date:    4-17-2009
Number of Hours:    5.50
Brief Description:    Engine wiring continued
I started the day by dismantling an EFIS/EM connector to remove the wiring for the traditional engine RPM transducer and install the RPM wire from the left P-Mag. After the connector was reassembled I wired the oil and fuel pressure sensors, the carburetor temperature sensor, The main alternator shunt and to finish I wired all the wiring related to the left P-Mag.
