Date:    2-20-2009
Number of Hours:    1.75
Brief Description:    Fuel pump overflow line installed...
Today was a day for odds and ends. I started by installing the fuel pump overflow line fitting. Then I had to adjust the angle of the fittings that go to and come from the oil cooler before connecting the oil hoses. Finally I bolted on the crankcase ground cable.
