Date:    12-6-2008
Number of Hours:    2.50
Brief Description:    Engine mounting
I decided to trial fit the engine to the engine mount to see how everything would fit. The fit is tight. I had to remove a fuel pump hose fitting to get the engine to clear the mount. After that it was some gentle persuasion before I was able the get the shock mounts and bolts to fit into the engine attach fittings.
