Today was a mixed work day. My brother Bernie and I started with the securing of the fuel quantity indicating system adapter harness. While we were working under the panel we secured and spiral wrapped more wiring at potential chafe points. To finish off with wiring to do items we secured the wiring for the aileron trim servo and control stick harness with tie wraps and heat shrink. Next we worked on the engine breather tube installation but had difficulties and kinked the tube so a new one is on order from Van's. Lastly we prepared and installed the rudder control cable fuselage exit point fairing.
