Date:    8-22-2009
Number of Hours:    5.75
Brief Description:    Fuselage upper forward skin riveting...
With the aircraft wiring completed it was time to rivet on the last skin. My brother Bernie helped as usual with the riveting and so the last skin was installed. For the skin riveting the fuel tank vent line had to be removed for access so I took the opportunity to also epoxy on the fuel tank vent line inlet screens. While the epoxy was curing some needed rework of the right NACA inlet was carried out and the inlet installed.
