5-18-2009 |
4.00 |
Transponder back shell installation... |
I had forgotten to install the the transponder connector back shell on initial installation. I removed all the connector pins again, slid on the back shell, repinned the connector and secured the back shell. Then I turned to the glareshield, compass and map light dimmer installation. I wired the power, ground, transponder and reostat dimmer wires. |
