Date:    5-5-2009
Number of Hours:    6.75
Brief Description:    Magnetometer installation...
I started today by cleaning, abrading, alodining and priming the parts for the magnetometer mount, the aft fuselage wiring harness support rail, the instrument panel extension and the cowl attachment strips. While the primer was drying I installed some supplemental snap bushings in the electrical panel and the sub panel for wiring pass through as the existing ones are rather full. Then I ran ground wires for the two voltage regulators, crimped on terminals for the starter solenoid circuit and for the starter engage light circuit. Once the primer was dry I riveted the magnetometer mount to the F-707 bulkhead as well as reviting and screwing the aft fuselage wiring harness support rail to the F-707 and F-708 bulkheads
