In todays work session I started by mounting the landing and taxi light wig wag flasher unit on the forward face of the subpanel. I also installed a snap bushing in the subpanel for routing of the wiring harness as well as drilling holes in the subpanel for screw driver access to the EFIS/EM connector retaining screws. Following this I mounted a dedicated ground block for all avionics and audio grounds. Then I installed the EFIS/EM shielded cables ground to the case ground and the EFIS/EM main ground cable to the dedicated avionics ground block. Finally I pulled the magnetometer and OAT cables through the airframe to their respective hook up points.
