Date:    3-25-2009
Number of Hours:    8.00
Brief Description:    Fuel and electrical system component installation
I carried on from yesterdays work session by modifying my fuel system firewall fitting mounting blocks to a four bolt retention system. I also did this to the engine manifold pressure distribution system. Then I turned to the electrical system by fabricating the cables from the main buss to the essential buss diode. Next I fabricated the cable from the essential buss for the essential buss solenoid. Finally I fabricated a hat section to mount the hot battery buss. I installed anchor nuts on the hat section, riveted the hat section to the firewall and installed the hot battery buss.
