5-25-2008 |
6.50 |
Canopy lift strut and control stick installation |
I started the day off by drilling and mounting the C-728 and C-729 mounts and mount spacers to the aft canopy decks. Then I installed the lift struts. Following this I mounted the Wd-611 control column sticks and the Wd-612 control column push rod. I finished the day by installing the F-716B seat rib access plates. |
