Date:    12-19-2007
Number of Hours:    3.75
Brief Description:    Instrument panel considerations
I clecoed the panel and subpanel components together. I cut and pasted or drew actual size images of displays, a map box and radios to the panel to see where I needed to move the panel support ribs. Then I cut the support ribs off at the subpanel and match drilled aluminium angle to the ribs to be able to attach them to the sub panel at more optimized locations.
