I started the day by installing the F-704A cover support rib retaining bolts, making and installing the F-704 center section spacers, riveting on the forward and aft F-704C/D and riveting on the F-704G shear bars. I then set aside the F-704 bulkhead and comenced work on the F-705 bulkhead. I trimmed the F-705B to length then located the F-705B/C/H on the the F-705A and match drilled them as an assembly. After this I installed the F-634 seat belt anchors on the F-705. Finally I fabricated from aluminium angle the left and right F-705G for the tip up canopy latches.
