Date:    11-23-2009
Number of Hours:    3.50
Brief Description:    Landing and taxi light connectors added
Today I decided to add molex connectors to the taxi and landing light installations to be able to quickly remove the wing tip fairings or light assemblies if needed. I also added clamps to secure the wiring. Another job that was on my "to do" list for a while was to remove the exhaust pipes at the cylinder exit and debur from the inside the EGT probe hole that was drilled. Also the #1 cylinder had had the EGT probe hole drilled in a bad spot so it interfered with the ignition plug so I packaged up that pipe and sent it to Larry Vetterman to get fixed up.
