10-20-2009 |
3.00 |
Wing tip fairing primer and UV blocker applied |
In the morning before going to work I sanded and then primed the wing tip fairings a second time. While the primer was drying I sanded the nose wheel fairing. Then I was out of time and went to work. Later after I was back from work I abraded the primer I sprayed ealier in the day and applied the UV blocker. |
