Date:    2-9-2007
Number of Hours:    5.75
Brief Description:    Installed right fuel tank, removed left wing skins
I started the day by doing another leak check of the right wing tank after having sealed the tank access panel. All was well so I installed the tank on the wing, see image 1. Then with the help of my wife Meta we removed the left wing skins from the wing skeleton and stripped the vinyl from the interior surface and the rivet lines of the exterior surface, see image 2. This was followed by deburring of the wing skeleton as well as dimpling and countersinking where necessary, see image 3.
