Date:    10-13-2009
Number of Hours:    3.00
Brief Description:    Elevator painting preparations
I was going to clean, etch and abrade the elevators today but after looking at the fairing installation I decided the fairings needed work first so I did some sanding then mixed up some micro and did some filling. While I had the epoxy out I also bonded on a flange on the engine cooling plenum aft left corner where I had previously added on an extension to close the gap that was there. Then while the epoxy cured I worked some on the engine manifold pressure supply line due to an outstanding issue not dealt with yet. Then it was time to quit and go to work.
