Date:    8-24-2015
Number of Hours:    3.50
Brief Description:    sub panel
I worked on the sub panel this past weekend. I made the F-644 ribs and drilled the control cable brace. I riveted the forward rib connector. I then drilled the holes where it connects to the firewall.I was not supposed to do this yet. This rib needs to line up with the forward top skin. I was worrying about this all day. I lucked out. the rib lines up just fine.
