The fuselage has been put on the stand. I actually shortened it by 2 inches from the plans and think it would be okay if it were shortened by two more. I installed the brake reservoir and started to install the brake lines. I damaged the brass fittings so I will need to new ones. After many attemps to get the fuel lines right, I think I found a good method on the forums. I will need to order more tubing as well. I got the control sticks in after much fumbling with the washers. I also clamped the horizontal stab in place just to get a visual and start fitting.
