8-26-2014 |
1.25 |
forward covers |
I am a little frustrated with Van's at the moment. I spent over an hour fitting this bracket for the forward cover. I have seen other builders complain about these brackets. they are not mentioned in the manual. There is not enough clearance for the pull rivets, especially the rivets that are called out on the plan. The mounting holes should be pre drilled in F-7101 and brackets mounted prior to F7101 installation! |
