Date:    4-28-2017
Number of Hours:    5.00
Brief Description:    cowling
More cutting and fittiing of the cowl. This thing moves around quite a bit. The fit is mostly good,
but one of the issues is that the upper hinge uses a smaller pin. This leaves a lot of slop. Most of the hinge around the firewall perimeter has been drilled.I just need to fit the left side , then I can install the side hinges.
