10-31-2010 |
4.00 |
Wing Stand |
With Rons carpentry skills a wing stand took shape. I used a pattern that I traced from my friend John's RV-7 leading edge tip, They are a little over cut to make room for foam. The other side will support the wing spars I made it 30 " wide as my room to work is going to be a bit tight , and it has wheels too. |
