2-6-2019 |
3.00 |
New FWD VS Spar arrives, can finally move forward |
My new FWD VS spar and doubler arrived from Van's so that I could start moving forward again with construction of the kit. Drilled and trimmed the FWD VS spar and doubler, final drilled all FWD rib and spar attach points, assembled VS assembly and clecoed VS skin to test fit, final drilled and match drilled VS skin and assembly where called out by the plans. Lots of little adjustments needed in fluting and positioning to get the skin fit well. |
