Date:    8-31-2014
Number of Hours:    4.00
Brief Description:    Left Tank vent line
I fabricated a vent line that will run from an AN fitting in the inboard rib out to the high point of the tank which is by the fuel cap. The vent line runs straight through each rib until inside the inboard most bay. It requires a two bends to line up with the an fitting. The vent line is also flared to attach to the AN fitting in the inboard rib. The wires for the capacative plates also run through each rib with the vent line.
