6-14-2020 |
2.00 |
Riveting rudder skeleton |
Spent a bit of fun time today with the pneumatic squeezer riveting the rudder skeleton. The squeezer sets the rivets so consistently and there are only two that need drilled out which is a job for another day. Once these two are fixed and two more set by hand where the squeezer won't reach (because the C yoke is still lost in action) I should be able to rivet the beloved R-710. Also set up the lead weight in the top of the rudder by setting flush rivets on a small strip to secure the nutplate. Seemed to go well and on closer inspection the spray painting of the primer looks of a good standard too. |
