Date:    4-26-2020
Number of Hours:    5.00
Brief Description:    Rudder work
Spent some time working on the rudder today. Started out with cutting all of the L angles to size and shape and then a loooong process of filing and sanding to get a smooth sharp edge free finish with also appropriate radi.
Then attached them to the rudder skin and drilled out to 40 all the holes and started deburring them. Also used a soldering iron to remove the bluing from the outside of the skin. When laying the rudder out beside the vertical stabiliser you start to get an idea of just how big the empennage is.
