6-17-2020 |
2.00 |
Even more riveting |
Got really stuck into riveting the horizontal stabiliser with the skeleton riveted together. Set five blind rivets on HS008 but short one blind rivet on the left hand side as I used these optional blind rivets on the bottom of the rudder horn. Will have to order a batch. Did a couple of lines of flush riveting on the skin and then when it got too late to pound rivets I moved onto using the squeezer on the 00006 and 00005 and HS706 on the top side of both. Looking really good. The slim I applied earlier in the build didn't go right as I used 3.5 rivets when I should have upsized to 4.0 so will have to fix this. |
