2-17-2008 |
5.00 |
Right wing (finally!!) |
Started on right wing. Drilled and clecoed wing tip to spar. Drilled holes for rib #9. Cut and mounted 'L' bracket to wing tip. Drilled and clecoed aileron horn channel in place. Made aileron horn mounting brackets. Drilled holes and clecoed in place. Deburred all holes. |
