Date:    11-5-2006
Number of Hours:    3.00
Brief Description:    Left wing (cont)
Aligned, clamped, drilled and clecoed rear spar channel. Drilled holes in baggage locker rear plate. Doesn't look like you can mount it until the bottom skin is in place. Left wing skeleton fully assembled. 45 degree tip line marked. Center of hole for aileron rod marked. Will make cuts once sekelton disassembled for deburring. Began drilling all holes to final size.
