Drilled safety wire holes in both piano hinges. Used scrab piece clecoed in place to stabilize drill bit. Cut hinge pins to length. Safety wired trim hinge pin. Finished riveting bottom side of elevator. Fitted elevator to stabilizer. Used rivet pins to hold in place while inserting hinge pin. Finished riveting top side of elevator. Left trim actuator clecoed. Left stabilizer side of piano hinge clecoed in case I need to separate the two pieces for storage or later fitting. Left wiring of the trim actuator undone for ease of storage.
