Date:    4-9-2020
Number of Hours:    2.00
Brief Description:    ELEVATOR: Rivet second skin
Positioned skins in order to have correct nesting of E-1008B into E-1008A.
Clecoed all the ribs halves and the skin to the spar.
Riveted using the procedure indicated with the long bucking bar resting on the work bench edge.
Riveting the bottom left elevator has been fairly easy with no damage to skin and to spar.
Unfortunately for the top right elevator i got two little skin damages. in one case i had to drill out the rivet and replace. the rest worked ok.
Top skin of the left and right elevator in the trim cut-out area are NOT riveted as this will happen when the trim hinges will be positioned.
