3-12-2020 |
2.00 |
HS Rivet HS Doubler, Front spar caps and bracket t |
Preassembled front spar with HS-1002 with front spar caps HS-10013 and front spar attachment brackets HS-1008 L&R. Rivetd with different types of rivet depending on thickness of material. Final drilled few holes to #30. All the rivet have been set using the pneumatic squeezer with very good results. |
