3-12-2020 |
0.50 |
HS Bolt Hinge Bracket assembly to rear spar |
Consulted torque table on section V (page 5-20) Determined the friction drag torque on the nyloc nut around 5-6 Inch/pounds Added the 6In/lbs to the self locking nut torwue value (28 in/lbs) and final torqued at 34 in/lbs. CHECK IF VALUES ARE CORRECT WITH LUCIO. POSSIBLE SLIGHT OVERTORQUE BECAUSE OF USING THE SELFLOCKING TORQUE VALUES INSTEAD OF THE NORMAL AN365 (20-25 in/lbs). |
