10-2-2019 |
1.50 |
VS rivet rear spar caps to spar |
riveted with squeezer, but very bad results. had to drill few rivet out. Redone with bucking bar and with rivet gun.....results barely acceptable. Probably too high pressure and not perfect alignement. Drilled out 7 rivets and replaced 2 with ooops rivet. Riveted again the bottom hinge with Lucio's Help Review rivets with Lucio Castrogiovanni, drilled our few more rivets, redriven rivets on 20 / 11/ 2019 |
