4-16-2014 |
1.00 |
Rudder pedal assembly #3 |
Removed the rudder pedal assembly, greased the critical areas, secured the assembly, torqued, and then added cotter pins where required. Also added the grove brake reservoirs to the brake cylinder assemblies. Rudder pedal assembly installed permantly to the aircraft. |
