Date:    11-2-2013
Number of Hours:    2.00
Brief Description:    Bottom skins #1
Pulled out the bottom skins and removed the blue vinyl. I started to put the left side in place and realized I put two rivets where I should have, so out they came.
I temporarily put the screws into the skin and gear towers and removed those as well so the skin would fit in.
Once the skins were in, I matched drilled the required #30 and #40 holes. I also opened up the holes for the gear brackets so that I can get a socket on them in the future.
I'm working days the next couple, so on Monday, I'll get the skins off, debur them and do the required dimpling and countersinking.
