4-9-2013 |
1.00 |
Fuselage disassembly #2 |
Removed all of the fuse pieces off that weren't required for the next few steps. I removed the seat rib assembly and clecoed the forward fuse floor to the front and rear flanges of the centre section. I machine countersunk the #30 holes in the two rivet lines to accept a #30 dimple. I then removed the front skins and reclecoed the aux longeron. With the Andair fuel valve, the next step doesn't work with the F-883-1, so I'll have to devise a bracket system for the fuel valve. |
