2-20-2013 |
2.00 |
Seat Rib Assembly #2 |
Entry #2 today. Finald drilled the bulkhead to #30. Final drilled all of the nutplate attachment holes in the F-814C-L/R. Clecoed the F-814C-L/R. to the F-814A-L/R seat ribs. Clecoed the seatbelt anchors and the F-805D brackets and matched drilled to #30. Match drilled all the #30 holes. Also pulled out the electric ailreon kit, and started addressing the brackets in both seat ribs. Using the template, I matched drilled the holes in the F-814L and traced the area to be cut out. Tested the bracket for fit, all good. Also match drilled the other bracket to the F-814R That's enough for the night. |
