2-9-2013 |
4.00 |
Landing gear box assembly #1 |
Started off by getting the parts for the gear tower assemblies together and then seperating the aft and forward corner angles. I clecoed everything together to see what it would look like, the removed all the parts and fluted the F-802A-R/L-1 and the F-802B-R/L-1. WHen the wledment was attached, you could see the need to flute the parts as tehre was approximately 1/4 inch gap. The parts were clecoed back together for the the left and right gear towers and all of the #30 holes were matched drilled along with the #40 holes. Once the parts were matched drilled, I taped a template for the F-802C R/L and confirmed the distances and dimensions. Once satisifed, I match drilled the screw holes in the template to the F-802C's. Once done, I then attached nutplates and match drileld for the #40 holes. The modification is common with RV-8s inorder to allow for more room in the gear tower to torque nuts/bolts and just have more access to do work. |
