9-30-2012 |
0.50 |
Retaining clip |
After final closing the ailerons, I made a retaining bracket for the flap hinge pin. An inch of left over flap hinge was used. I cut the hinge so thatI had two eyelets and then matched drilled for 3-5 flush rivets. Drilled a hole for the bolt and tested the fit. Works great. I have a little bit of the hinge pin that has to be removed at each end. |
