2-11-2012 |
1.00 |
Left wing fuel tank part #8 |
Worked on the fuel drain and the deluxe locking fuel cap. The fuel drain was secured onto the skin using a bolt and I drilled the holes with #40, cleoced and continued until it was completed. The fuel cap flange was marked for centre and a line drain across the flange. The mark was lined up with the two middle holes, clamped and then drilled with a #40. I drilled, clecoed each hole and moved along until completed. No issues. |
