4-21-2010 |
1.00 |
Start work on the vertical stab |
Clecoed the VS 808PP spar doubler to the VS 803PP along with the 410, 411, and 412 hinge brackets. Used the VS 803 and 808 as a guide and drilled the two holes for the VS 410 hinge bracket. Fluted and deburred the ribs and clecoed. Final drilled the VS 803, 808, 410, 411, and 412 to #30 as well as the rib spar attach holes. Clecoed the VS 801 skin to the assembly, final drilled the skin |
