Date:    4-14-2010
Number of Hours:    2.00
Brief Description:    Working on the Right side of the HS
Worked on the right hand side of the HS tonight. Riveted the HS 707 to the HS 801. Clecoed the the HS 708 to the HS 707 and the HS 801. Clecoed the HS 706 to the HS 801.
Riveted the top side of the HS 707 to the HS 801. Removed the HS 708 and Clecoed the HS 702 to the HS 706, HS 707 and 708. Blind riveted the HS 708/HS 702/HS 707. Riveted the HS 702 to the HS 706. Started to finsih flush riveting the HS 801 to the HS 702 and HS 708. The flush riveting is getting much better.
Pictures to be posted later.
