3-14-2010 |
2.00 |
Ribs prepared |
Ribs HS-404, 405, 706, 707, and 708 all deburred. Ribs identified left and right side of the HS. Using the dimensions in Sec D-D, hole locations marked. Holes drilled to #40. HS-702, HS 603, HS 706, 707, and 708 clecoed together. All rib holes drilled to #30, except HS-708 to HS-603 holes |
