5-18-2019 |
8.00 |
Install fuel system components and alternator |
- Installed the engine driven fuel pump fittings and hoses, coating all o-ring seals with Fuel Lube. - Installed the VA-128 fuel pressure restrictor fitting at the engine driven fuel-pump KB-090T fitting. Installed the fuel pressure line between the restrictor and the fuel pressure sending unit. - Installed the primary alternator |
