Date:    4-6-2019
Number of Hours:    2.00
Brief Description:    Oil line fittings
Installed the VA-128 restrictor fitting for the oil pressure sensing line.
Installed the 2 oil cooler line fittings in the ports on the engine accessory case.
Installed the AN816-4D manifold pressure gauge line fitting in the bottom right corner of #3 cylinder
