Date:    8-21-2007
Number of Hours:    4.00
Brief Description:    Cabin Frame Construction
- Drilled the aft F631E joining plate to the channels - Laid out the holes for the aft end of the F631B inner strap. I found 1 13/32" came out pretty even for spacing. - Drilled the F631B inner strap to the aft channel, starting in the middle and clecoing as I went, per the instructions.
