7-27-2007 |
1.50 |
Drilled Rear Spar Attach point |
Rechecked proper wing alignment and incidence and then drilled hole for rear spar attach bolt. Started at #30 and worked up to 5/16" using an assortment of drill sizes. Attached bolts and torqued to 100 in-lb minimum spec. Used temporary cotter pins. |
