Date:    7-17-2007
Number of Hours:    2.00
Brief Description:    Wing Mate Prep Work
Used the lathe at work to drill out the flap pushrod ends to #3 and then tap to 1/4-28. Primed the inside of the tubes w/ SEM self-etch. Verified the rod end bearings on both the flap push rods and control bearing rods fit properly.
