3-9-2007 |
6.00 |
WD-657 External Step |
Laid out and drilled the holes for the step plate. The plate is steel so it took a good bit of work. Bent and then cut the trailing edge corner to fit the moldline of the compound curve in the F770 fuselage skin. |
