Date:    1-4-2007
Number of Hours:    2.50
Brief Description:    F6118 Rudder pedal brace
Fab'd the rudder pedal brace and mounted to rudder tubes using F6115 center bearing block. Drilled and clecoed brace to firewall stiffener and then match drilled w/ center bearing block in the 3 corresponding positions. Note: the farthest aft position did not fit easily and I may want to create a new center bearing block if I decide to mount the pedals in this position.
